Shiny Side Up Posted April 5, 2016 Share Posted April 5, 2016 Is this the real answer to the pivot bearing problem at the final drive for the paralever bikes - Thoughts? Anybody have experience with this product? http://www.beemershop.com/Merchant5/merchant.mvc?Store_Code=BS&Screen=PROD&Product_Code=TRA11094 Link to comment
dirtrider Posted April 5, 2016 Share Posted April 5, 2016 Morning Shiny Side Up Might be, you never really know until the test miles come back with positive or negative findings. Other brass bushing set-up's have failed so this one might be a flop also. Personally I haven't ever had an issue with properly greased & properly-installed/properly-greased OEM parts. Link to comment
Alfred02 Posted April 5, 2016 Share Posted April 5, 2016 Morning Shiny Side Up Might be, you never really know until the test miles come back with positive or negative findings. Other brass bushing set-up's have failed so this one might be a flop also. Personally I haven't ever had an issue with properly greased & properly-installed/properly-greased OEM parts. Same I replaced them with OEM parts on a 2004 1150RT and the current owner has not reported any issues. He has the bike now for about 4 years and done 15k+ kms on it. Just use simple blue Loctite. That's all that is required Link to comment
Railbender Posted April 5, 2016 Share Posted April 5, 2016 There is an ongoing thread on ADVRider about a new style pivot BUSHING that looks very promising. http://advrider.com/index.php?threads/rear-pivot-bearing-details.977621/ As soon as the improved version is available I am going to try them. Link to comment
Shiny Side Up Posted April 5, 2016 Author Share Posted April 5, 2016 Morning Shiny Side Up Might be, you never really know until the test miles come back with positive or negative findings. Other brass bushing set-up's have failed so this one might be a flop also. Personally I haven't ever had an issue with properly greased & properly-installed/properly-greased OEM parts. For now - I'm with you... I tried the bushings from rubber chicken and they were not the "end all"!! In fact, the OEM bearings lasted longer than the bushing. I went back to the OEM bearings and with a little maintenance every so often, as you state, they wear well. We repack wheel bearings - don't we?!?! I want to see a track record on this "fix". Any moving part is eventually gonna fail - JMHO. Link to comment
