willimike Posted May 30, 2016 Share Posted May 30, 2016 Will the power cable for a Nav III fit the BMW Zumo 550? Link to comment
dirtrider Posted May 30, 2016 Share Posted May 30, 2016 Morning willimike A quick look says the base power cables are different. The USB cable will probably work on both units. Link to comment
Marty Hill Posted May 30, 2016 Share Posted May 30, 2016 I have a spare cable from the Zumo 550 to the battery. Is that what you need? Link to comment
gator1606 Posted May 31, 2016 Share Posted May 31, 2016 I sure could use the Zumo to battery cable. If not already taken. Thanks Bill P Link to comment
willimike Posted May 31, 2016 Author Share Posted May 31, 2016 Hi Marty...I have the Zumo 550 power cord, but was looking for the BMW connector since it plugs in to the power supply on my 2009 RT. Does your connector plug in or just have the bare wires that connect to the battery? Link to comment
Marty Hill Posted May 31, 2016 Share Posted May 31, 2016 Hi Marty...I have the Zumo 550 power cord, but was looking for the BMW connector since it plugs in to the power supply on my 2009 RT. Does your connector plug in or just have the bare wires that connect to the battery? Sorry, don't have the connector. Link to comment
Marty Hill Posted May 31, 2016 Share Posted May 31, 2016 I sure could use the Zumo to battery cable. If not already taken. Thanks Bill P Bill, I sent you a PM. Link to comment
Bernie Posted June 1, 2016 Share Posted June 1, 2016 I think I have a extra cable, Zumo 550 to BMW connector plug for the 2005 and newer RT. You want new or used? BMW does sell a repair plug, which is the connector for the harness and 2 long wires, so you can connect it to the Garmin Zumo cable. Is that what you need? Link to comment
