biometrics Posted July 19, 2016 Share Posted July 19, 2016 These two bikes are very similar and have many interchangeable parts, but some do not interchange, for example the foot peg mounting plates. Can anyone tell me if the center stands are interchangeable between these two models? the part numbers are different on the parts fiche, but the diagrams are identical... I am looking to put an instatrike kit on an R1100RT, and I think the kits are different simply because they were designed at different times. I would like to use the R1150RT kit on the R1100RT and if the center stands ARE interchangeable, this should be possible. The later bike (R1150RT) uses the E-Trike kit, and the R1100RT uses the Instatrike kit. The E-Trike kit is less expensive and easier to put on and take off... hence my desire to use the later model. So has anyone actually interchanged the center stand between these two models? They look the same on the fiche diagrams... specifically talking about Part #1 in both diagrams. Link to comment
biometrics Posted July 22, 2016 Author Share Posted July 22, 2016 I guess nobody knows the answer to my questions... Link to comment
lkchris Posted July 22, 2016 Share Posted July 22, 2016 I know for sure that the illustrations being identical is meaningless. Link to comment
waynerd Posted July 22, 2016 Share Posted July 22, 2016 Possibly Mike, at Beemer Boneyard, could answer that question. A dealer is just going to reference the part numbers from their fiche. Link to comment
biometrics Posted July 25, 2016 Author Share Posted July 25, 2016 Thanks, I will check with BB. Link to comment
AndyS Posted July 25, 2016 Share Posted July 25, 2016 I am pretty sure they are NOT interchangable. This is based on work I din many years ago, so could be wrong. Link to comment
