Spin balancer BMW wheel adaptors
mitchntx
I have access to a snap-on spin balancer, but need the gear (cones?) to adapt it to the BMW rim.
Can someone point me to where I might bu a pair?
Or look at the K&L catalog online to make sure the ID will fit . K&L has a full selection of the adapters for about all the BMW's.
http://www.klsupply.com/2016ProductCatalog/2016KLCatalog.aspx
No, they won't be just a few dollars.
Maybe Marc Parnes would make you some up with your machines spindle size. His items are reasonable .
http://www.marcparnes.com/BMW_Motorcycle_Wheel_Balancer.htm
Edited by Tri750
Morning Mitchntx
First you need to get the model number of the Snap-On balancer & possibly the balancer shaft diameter (not all Snap-On balancers will handle motorcycle wheels).
Then call Snap-On & tell them what adapters you are looking for (size wise) & give them the balancer model number & possibly the shaft diameter. (they should be able to help you out)
Or use the live chat at Snap-On if you don't want to call them.
Snap-on __click here
Thanks DR.
Exploring possibilities other than Snap-On because Snap-On is crazy expensive for simple turned delrin cones ... not unlike BMW OEM parts.
Must be super pricey to etch Snap-On or BMW onto stuff.
Edited by mitchntx
