KSB Posted August 1, 2018 Share Posted August 1, 2018 The rear tire on my 2016 R1200RT-LC loses pressure very slowly; it goes from 44psi to ~35 psi overnight and then stays at that pressure. Developed a leak during my last trip and I had the leak plugged; can the plug re-seal itself when the pressure reduces to ~35 psi? The TPM tracks the pressure perfectly when riding and stops decreasing at ~ 35 psi. I use a valve stem cap at all times. The tire is a Michlean Road 5 with about 6K miles. A new tire is on-order, but I wanted to see if anyone has experienced a problem like this. Thanks Link to comment
dirtrider Posted August 1, 2018 Share Posted August 1, 2018 Ongoing thread on this bike here-- http://bmwsporttouring.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=1015789#Post1015789 Link to comment
KSB Posted August 4, 2018 Author Share Posted August 4, 2018 Found another nail in the tire Replaced the tire with new $$$ Cheaper than a blow out! THANKS for all the feed back Link to comment
